100nF 50V ceramic capacitor lead dimensions
I need the datasheet for the 100nF 50V ceramic capacitor. Specifically, I need the lead length and lead spacing of this component.
Zanima me ima te li datasheet za sljedeći artikal:
Keramički kondenzator 100nF 50V
https://e-radionica.com/hr/keramicki-kondenzator-100nf-50v.html#
točnije me zanima duljina i razmak nožica komponente.
Također ako mi možete reći imate li 1000 komada na skaldištu te koje bi bilo okvirno vrijeme isporuke.
Originally submitted via email support on 28 June 2021. Migrated to the forum for community visibility.
The datasheet is not available. However, the lead length is approximately 14mm and the lead spacing is approximately 3mm.
hvala Vam na upitu.
Nažalost, ne možemo Vam isporučiti tu količinu kondenzatora, trenutno ih imamo 43 na stnaju koja su dostupna za kupovinu.
Također, nemamo datasheet za kondenzator.
Duljina nožica je cca14mm, a razmak nožica cca 3mm.
