10mm red LED maximum continuous current for daylight signal use
What current was used to capture the photo at https://soldered.com/productdata/2022/05/238043-Edit.jpg? What is the maximum continuous current? I’m interested in using this as a signal lamp in daylight.
Hvala za sliku:
Pri kojoj struji je ona snimljena?
Kolika je najveća kontinuirana struja?
Zanima me primjena kao signalna lampica pri dnevnom svjetlu.
Hvala, pozdrav!
Originally submitted via email support on 24 July 2023. Migrated to the forum for community visibility.
The current used to capture the LED in the photo is uncertain, but the maximum current through the LED is around 15mA. 20 mA is the absolute maximum limit that may damage it.
nisam siguran po kojoj struji je LE-Dioda snimljena na slici, ali najveća struja kroz LE-Diodu je oko 15mA. 20 mA je krajnji limit koji ju možda može oštetiti.
Is the manufacturer and part number known?
Hvala za brzi odgovor!
Je li poznat proizvođač - oznaka?
Hvala, pozdrav,
No, but these LEDs are generic and share the same properties. You can find more details about 10mm red LEDs on this page: 10mm LED Technical Specifications and Power Characteristics
Reading through this, it appears that 20mA is actually safe to use and will provide greater brightness, so that current can be used.
Koliko vidim ne, ali takve LE-Diode su generičke i dijele ista svojstva, na ovoj stranici možete pronaći više detalja o crvenim 10mm LE-Diodama: 10mm LED Technical Specifications and Power Characteristics
Čitajući malo ovo, izgleda da je struja od 20mA ipak sigurna za koristiti i dati će veću svjetlost, pa se može koristiti ta.
