Do you have a 6-pin connector like this? It needs to be at 90 degrees or have longer pins that can be bent.
Jel imate ovakav konektor sa 6 pinova, mora biti po 90 stupnjeva ili da ima duze nozice da se moze savit.
Originally submitted via email support on 5 April 2018. Migrated to the forum for community visibility.
Based on your request, we can offer you a 6-pin foldable header (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics).
The question is how long the pins need to be.
Pitanje je jedino koliko dugačke nožice trebate.
The pin length on the 6-pin foldable header is approximately 12mm.
There should be room for bending, depending on how you plan to solder them.
vezano prethodnim telefonskim razgovoro, duljina nožica 6-pinskog složivog header je cca 12mm.
Po mojoj osobnoj procjeni, mjesta za savijanje bi trebalo biti, naravno, ovisi o načinu na koji ćete ih zalemiti.
