8-channel SSR relay module: connecting power, control pins and load
I recently purchased an 8-channel SSR relay module from your website. I have a 5V power supply available (the specifications state that 5V is sufficient). My question is: do I connect power to the DC+ and DC- pins, connect the channel pins (CH1-8) to GPIO pins on my board, and then connect the load devices (mini pumps in my case) to the SW1-8 terminals to allow current to flow through them? I’m confused about the purpose of the DC+, DC- and CH1-8 input pins below the connectors, so please clarify this for me.
Kupio sam nedavno (https://soldered.com/product/module-with-ssr-relays-8-channel/ ) sa Vaše stranice 8 kanalni relay. Imam napajanje od 5V koje mogu dovesti do njega (Piše u specifikacijama da mu je dovoljno 5V). Moje pitanje je: Na pinove koje imam na njemu DC+, DC- i ostale pinove za kanale trebam dovesti struju i povezati kanale sa GPIO od moje pločice, a na drugoj strani gdje su SW1-8 spojiti u mom primjeru mini pumpe (koje sam isto kod Vas uzeo) kako bi struja tekla do njih?
(Pitam jer mi ovi ulazi sa DC+ DC- i CH1-8 ispod pinova stvaraju pomutnju pa da mi moda Vi razjasnite)
Originally submitted via email support on 20 April 2023. Migrated to the forum for community visibility.
Connect your power supply to the DC+ and DC- pins. The CH pins are the control inputs where you apply a digital signal for each channel you want to turn on or off. You can connect them to your board’s GPIO pins using jumper wires or through the blue connectors—either method works.
Na DC pinove mu dovodite napajanje, a CH pinovi su pinovi na koje dovodite digitalni signal za svaki kanal koji želite paliti/gasiti. Možete ih spojiti sa žicama za prototipiranje, ili na plave konektore, svejedno je.
Ovdje je detaljan tutorijal za takve releje pa možete pogledati za detaljnije informacije.
