A4988 Stepper Motor Driver as replacement for Easy Driver 4.4
I’m working on a small project with an Arduino UNO R3 and an Easy Driver 4.4. I ordered drivers from overseas but I’m concerned they won’t arrive in time. Can I substitute them with one of your stepper motor drivers?
Poštovani, u izradi sam jednog malog projekta u kojoj je projektiran Arduino UNO R3 sa Easy driverom 4.4. Iako sam naručio Drivere iz Kine sumnjam da će stići do zadanog roka,pa me zanima da li se Easy driver može zamijeniti nekim vašim driverom za step motore? Srdačan pozdrav
Originally submitted via email support on 1 March 2016. Migrated to the forum for community visibility.
The closest equivalent we have is the A4988 Stepper Motor Driver: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Check the specification and datasheet to see if it will work for your application.
nešto najsličnije što imamo je ovaj stepper driver: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics Pogledajte prema specifikaciji i datashetu hoće li Vam se uklopiti.
Thank you for the quick response. Can a weaker driver power a motor from a CD-ROM?
Hvala Vam na brzom odgovoru. Da li imate samo web shop ili imate i neki ducan u kojem mogu odmah podici robu?
Onaj slabiji driver ne bi mogao pogoniti npr. motoric iz cd-roma?
A stepper driver and a CD-ROM motor are different things. A CD-ROM motor is a regular motor that you can power from any power supply. If you want to control it from an Arduino or Croduino, you just need a transistor between them.
Ovo što ste nam poslali je stepper driver, dok je motorić iz CD roma - običan motor. Njega možete pogoniti s bilokakvim izvorom napajanja, a ako kontrolirate iz Arduina/Croduina, treba Vam samo tranzistor između njih.
Imamo i dućan u Osijeku. Javite ako Vam je blizu pa šaljem više info.
