Is it possible to control more complex industrial systems with an Arduino Mega 2560 board? For example, controlling servo motors, sensors, pneumatic cylinders, all at the same time? Do you offer any other solutions or options, or would it be better to use something like a Siemens PLC for these types of tasks?
postoji li mogućnost upravljanja složenijim industrijskim sklopovima pomoću Arduino Mega 2560 pločice? Npr., upravljanje servo motorima, senzorima, pneumatskim cilindrima, sve u isto vrijeme? Nudite li vi kakva druga rješenja ili opcije ili je bolje da se takve stvari rade npr. na Siemens PLC?
Originally submitted via email support on 18 November 2021. Migrated to the forum for community visibility.
The Arduino Mega 2560 can control more complex processes. Compared to the Atmega 328, it has more memory and a greater number of pins. What executes and when is determined by the logic you implement in your code. To run multiple things at the same time, you need to organize and write your code well. So for the application you described, it is possible to use the mentioned microcontroller - you just need to write good code.
In industry, PLCs are more commonly used because they are adapted to industrial standards, but there are also PLC solutions with microcontrollers like the Atmega 2560. If anything is still unclear or you need a more detailed explanation of any part, feel free to ask.
Arduino Mega 2560 može upravljati složenijim procesima, a uz veću količinu memorije u odnosu na Atmega 328 ima i veći broj pinova. Kada se što izvodi određujete logikom koju implementirate u kodu, a da se više stvari izvede u isto vrijeme potrebno je dobro organizirati i napisati kod. Dakle za upotrebu kakvu ste opisali je moguće koristiti navedeni mikrokontroler samo treba dobro napisati kod. U industriji se više koristi PLC jer su prilagođeni industrijskom standardu, ali postoje i rješenja PLC-a s mikrokontrolerima poput Atmega 2560. Ako vam još nešto nije jasno ili treba detaljnije objasniti neki dio slobodno pitajte.
