It’s theoretically possible to build the device you described, but certain adjustments are needed for voltage regulation. The key challenge is finding a step-down (buck) regulator capable of reducing the voltage by such a small amount, which is difficult to achieve in practice with standard modules.
As an alternative, we recommend using an LM317 adjustable voltage regulator. With properly dimensioned resistors between the ADJ and Vout pins, you can precisely set the desired output voltage. The connection schematic and calculation formula are on the first page of the datasheet: https://www.ti.com/lit/ds/symlink/lm317.pdf
Regarding the solar panel, its efficiency depends heavily on how you use the Arduino and on available sunlight. We recommend using deep sleep mode whenever you’re not taking measurements or performing calculations, to minimize power consumption.
While the concept is viable and should theoretically provide enough energy to power an Arduino Nano BLE system, we cannot guarantee the functionality of the complete system in practice, as we have not realized such a project before. There may be deviations in actual charging efficiency and power consumption depending on conditions and components.
teoretski je moguće realizirati uređaj koji ste opisali, no potrebno je napraviti određenu prilagodbu u vezi s naponskom regulacijom. Ključni izazov je pronaći step-down (buck) regulator sposoban smanjiti napon za tako mali iznos, što je u praksi teško izvedivo s klasičnim modulima.
Kao alternativu preporučujemo korištenje LM317 podesivog regulatora napona, dostupan na sljedećem linku: https://soldered.com/product/lm317-adjustable-voltage-regulator/
Uz pravilno dimenzionirane otpornike između ADJ i Vout pinova, moguće je precizno podesiti željeni izlazni napon. Shema povezivanja i formula za izračun nalaze se na prvoj stranici datasheeta: https://www.ti.com/lit/ds/symlink/lm317.pdf
Što se tiče solarnog panela, njegova učinkovitost u velikoj mjeri ovisi o načinu korištenja Arduina te o dostupnosti sunčeve svjetlosti. Preporučujemo korištenje deep sleep moda kad god se ne obavljaju mjerenja ili kalkulacije, kako bi se potrošnja energije svela na minimum.
Važno je napomenuti da, iako je konceptualno izvedivo i na papiru bi trebalo biti dovoljno energije za napajanje Arduino Nano BLE sustava, ne možemo garantirati funkcionalnost cijelog sustava u praksi, jer do sada nismo realizirali ovakav projekt. Moguća su odstupanja u stvarnoj učinkovitosti punjenja i potrošnji energije ovisno o uvjetima i komponentama.
