Arduino Nano mini-B USB cable compatibility
Can I use this cable to communicate with an Arduino Nano? Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Pozdrav, zanima me ako mogu ovaj kabel koristiti za komunikaciju s Arduino Nano Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Originally submitted via email support on 20 May 2020. Migrated to the forum for community visibility.
The Arduino Nano has a mini-B USB connector on board. The cable you linked is the correct one for the mini-B USB connector.
hvala Vam na upitu.
Arduino Nano bi na sebi trebao imati mini-B USB konektor. Kabel koji ste dolje naveli je odgovarajući mini-B USB konektoru.
