I purchased an Atmega328p microcontroller board with LoRa transceiver and SMA connector, but I cannot find a description of the device anywhere. I don’t know how to upload a program to it.
Poštovani od vas sam kupio “Atmega328p microcontreller board with LoRa transciever and SMA connector”, ali ne mogu nigdje pronaći opis uređaja, ne znam na koji način mogu unijeti program u njega.
Originally submitted via email support on 3 January 2023. Migrated to the forum for community visibility.
To use the board, you need to install the Dasduino Board definition and LoRa library. Once installed, select the Dasduino Core (ATmega328P) board and you can try using some of our LoRa code examples. The device works like any other development board (such as the older Croduino or Dasduino), except it has LoRa built in.
ispričavam se što nemamo opis uređaja, ali potruditi ćemo se da ga dodamo u budućnosti.
Kako bi mogao koristiti uređaj, potrebno je da instaliraš Dasduino Board definition i LoRa library.
Kada ih instaliraš, potrebno je odabereš navedni board Dasduino Core (ATmega328P) te zatim možeš probati koristiti neke od naših primjera koda za LoRu kako je prikazano na drugoj slici.
Također taj uređaj možeš koristiti kao i svaku drugu razvojnu pločicu (stari Croduino, Dasduino) samo što ima dodatno LoRu na sebi.
