Bluetooth module disables serial port communication with Arduino
I’m building a final year project: a system for monitoring and managing sensor values in a workspace, based on an Arduino board and a C# database. I bought several sensors from you including a Bluetooth module, and I’m having a problem with it. When I set up the connection between my laptop and Arduino, I try to print the sensor readings (DHT11, MQ135, sound detector) to the serial monitor, but I get an error that the serial port COM 7 where the Arduino is connected is not available. When I connect the Arduino and laptop with just the cable, everything works normally.
Originally submitted via email support on 11 June 2017. Migrated to the forum for community visibility.
I assume your Bluetooth module is connected to pins 0 and 1. Those pins are used for serial communication between the computer and microcontroller, so they’re not available if you’re already using the module there.
I recommend you look up Software Serial for Arduino.
pretpostaljam kako si bluetooth povezan na pinove 0 i 1. Oni se koriste za serijsku komunikaciju računala i mikrokontrolera, pa nisu dostupni ako ih već koristis modul.
Preporučujem da googleš Software Serial za Arduino.
