Bluetooth Module firmware version mismatch with older devices
I sent pictures several days ago as requested, but have not received any response yet.
pred nekoliko dana sam Vam poslala slike koje ste tražili, ali još uvijek nismo dobili nikakav odgovor, a nama gori pod petama, lp [name removed]
Originally submitted via email support on 1 September 2022. Migrated to the forum for community visibility.
After consulting with engineering colleagues, we determined that the Bluetooth modules currently in our inventory have different firmware from the ones you sent in your pictures. Unfortunately, our supplier did not notify us of this change. The modules in your shipment had different firmware, and since the shipment was from less than a year ago, we no longer have modules with the firmware that matches yours.
We can offer you either to return the modules for you to attempt working with them, or a refund for the modules that don’t match your needs.
Regarding the module name you mentioned in your earlier email, this can be changed using AT commands. Here is a link with instructions on how to change the Bluetooth module name: https://maker.pro/arduino/projects/how-to-change-the-bluetooth-module-name-easily-with-arduino.
Nažalost, naš dobavljač nas nije obavijestio o tome. U Vašoj isporuci stigli su moduli s različitim firmware, a s obzirom da je isporuka bila prije nešto manje od godinu dana, nažalost više nemamo module s firmware koji Vama odgovaraju. Što se tiče imena modula što ste ranije napisali u mailu, to se može pomoću AT komandi promjeniti. Šaljem Vam link na kojemu imate upute kako s to može promijeniti: https://maker.pro/arduino/projects/how-to-change-the-bluetooth-module-name-easily-with-arduino.
