BME680 IAQ calculation and BSEC library linking issues
How can the Gas value from BME680 be used to obtain or calculate the IAQ (Indoor Air Quality index) and how should that value be interpreted?
Kako se iz vrijednosti “Gas” moze dobiti ili izracunati IAQ odnosno interpretacija te vrijednosti?
Originally submitted via email support on 4 February 2023. Migrated to the forum for community visibility.
To obtain IAQ from the BME680 sensor you need to use an additional Bosch library which is not open source and is only supported on certain hardware. There is a tutorial available where you can find more details.
Da biste dobili IAQ iz BME680 senzora potrebno je koristiti dodatan Boshov library koji nije open source i podržan je samo na određenom hardveru. Ovdje je tutorijal pa možete pogledati detaljnije.
Thanks for the answer. I read the tutorial. Can you confirm that based on what it says there, it follows that in this case (when using the BSEC library) the library you provide is not used?
Hvala na odgovoru. Procitao sam uputstvo. Mozete li mi potvrditi da po onome sto pise tamo proizlazi da se u tom slucaju (kada se koristi BSec library) ne koristi library kojeg vi isporucujete?
Yes, in that case only the BSEC library is used.
Da, u tom slučaju koristi se smao BSEC library.
I finally managed to try it. Unfortunately the recommendations given on that website do not help in solving the problem. The error occurs in the linking process.
I used the “basic” example that comes with the installed BSEC library. Do you have any idea how to solve this problem? I’m using Dasduino Connect.
Konacno sam stigao probati. Nazalost preporuke dane na toj web stranici ne pomazu u rjesenju problema. Gresku javlja u postupku “link-anja”.
(koristio sam “basic” primjer koji dolazi uz BSEC instalirani library.
Imate neku ideju kako rijesiti taj problem?
Koristim Dasduino Connect.
Attachment omitted in migration: 258c827b.png
When using such libraries, they check what board it is being uploaded to because it cannot be uploaded to every board. This library does that too, so it might be having issues with that. You can try using the ESP8266 board definition instead of Dasduino Connect because ESP8266 supports this library.
Kada se koriste takvi libraryji, oni provjeravaju kako se zove pločica na koju se uploada jer se ne može na svaku uploadati. Tako i ovaj pa ga možda muči to. Možete pokušati koristiti ESP8266 board definition umjesto dasduino connect jer ESP8266 podržava taj library.
