Is the connector (pinout) on the BMP180 sensor module compatible with the pinout on the easyC cable?
Da li je konektor (pinout) na ovom modulu:
Build your own weather station with our BMP180 sensor. This high-precision sensor measures barometric pressure, temperature, and altitude. – Soldered Electronics
prikladan za spajanje sa pinoutom na ovom konektoru
https://soldered.com/product/easyc-cable-6cm/
Originally submitted via email support on 18 August 2023. Migrated to the forum for community visibility.
Yes. The easyC cable is designed for exactly this purpose and should establish a connection with this sensor without any additional cables.
Da. easyC kabel je upravo za to i namjenjen i trebao bi ostvariti vezu sa tim senzorom bez dodatnih kablova.
