I have two questions. Is the bq27441 breakout board able to measure current flow of the battery while charging or discharging? If so, where is the output of the battery on the breakout board (VCC?).
Second question: I can’t check the PCB schematic on EasyEDA. Is there a PDF somewhere?
Originally submitted via email support on 17 April 2025. Migrated to the forum for community visibility.
The hardware files are available here: GitHub - SolderedElectronics/Fuel-gauge-BQ27441-breakout-hardware-design: Hardware design, BOM, gerbers and 3D files for Fuel-gauge-BQ27441-breakout designed by Soldered Electronics. · GitHub
Check for schematics in the OUTPUT folder. You can also open the files in KiCad, which is a free PCB design software.
The output of the battery is on the terminals, and the bq27441 can measure current during charging as well as discharging. You interact with the breakout using the Arduino library: GitHub - SolderedElectronics/Soldered-BQ27441-Battery-Fuel-Gauge-Arduino-Library · GitHub
