Cable assembly SKU 100851 connector dimensions
I am interested in the cable assembly SKU 100851. Is it possible to have a datasheet for this assembly? I need to know: cable length, wire section, and type of DC connector (inner diameter, outer diameter).
Originally submitted via email support on 12 February 2026. Migrated to the forum for community visibility.
Here are the measurements for the cable assembly:
cable length - 11cm
Cable thickness - 22AWG = 0.34mm²
Other measurements were provided visually.
Thank you for the reply. I have a representation of the counterpart that I need to connect to. My concern is about the internal dimension of the Jack connector. Can you verify this?
Attachment omitted in migration: image004.png
Attachment omitted in migration: image005.png
The internal dimension appears correct. It’s larger with some tolerance, so it should fit as intended. While I don’t have the exact connector to guarantee fit, here are the measurements:
I used the ‘stick’ part of the measuring tool to measure the depth.
