Is it possible to purchase just the e-Paper display without the module, or can the module be separated from the display to use the display independently?
Zanima me dali je moguće uzeti samo inkdisplay bez modula, ili ako je moguće odvojiti taj modul od displaya te koristitit display zasebno?
Originally submitted via email support on 17 February 2026. Migrated to the forum for community visibility.
The e-Paper displays are not sold separately. The complete Inkplate board is required to operate the e-Paper display. Running any e-Paper display requires complex hardware, a unique connector, and a software library - all of which are packaged together in Inkplate as a single product. If you need the part number for one of the Inkplate models, you can find it in the Hardware Details section on Inkplate Documentation | Soldered Documentation for each model page.
hvala na upitu, trenutno ne prodajemo e-Paper displaye samostalno. Cijela Inkplate ploča u kompletu je potrebna da se pokrene e-Paper display. Ako želite pokretati bilo koji e-Paper display potreban je složeni hardver, jedinstveni konektor i software library, sve od čega smo mi spakirali u Inkplate kao jedan proizvod. Ako vas zanima part number jednog od našeg Inkplate modela, možete vidjeti na Inkplate Documentation | Soldered Documentation i na pojedinoj stranici modela pod Hardware Details.
