Can NRF24L01 work with an analog video camera
Can an analog video camera be connected to the NRF24L01 transmitter module?
Poštovani, Može li se na Vaš predajnika spojiti predmetna kamera? Ako Da pošaljite 1 komplet NRF24L01 na adresu: [name removed], [address removed], ,[address removed], s plaćanjem preko HP. Unaprijed zahvaljujem. [name removed]
Originally submitted via email support on 13 June 2022. Migrated to the forum for community visibility.
What type of camera are you referring to?
The NRF24L01 module operates via SPI communication and requires a microcontroller to send data through the NRF24L01 module. Additionally, depending on which type of camera you use, you would need the same microcontroller to collect data from the camera and send it via the NRF24L01 module.
In summary, if you need something to wirelessly transmit data from an analog camera, this is not the right module because it requires digital communication (SPI).
o kakvoj kameri se radi?
NRF24L01 modul radi preko SPI komunikacije te za njegovu kontrolu trebate mikrokontroler koji bi slao podatke putem NRF24L01 modula. Također ovisno koja vrsta kamere se koristi bilo bi potrebno s istim mikrokontrolerom prikupiti podatke s kamere i slati s NRF24L01 modulom.
Ukratko ako Vam je potrebno nešto što će slati podatke bežično s analogne kamere onda to nije ovaj modul jer on zahtjeva digitalnu komunikaciju (SPI).
