I’m interested in connecting the 3-axis gyroscope from the CSP SENSE set wirelessly to a Croduino Basic2. Is this possible? What additional components would need to be ordered to make such a wireless connection work?
Zainteresiran sam za kupnju ovih proizvoda: 1. 2. 3. 4. Interesira me je li moguce 3-osni žiroskop iz seta SENSE spojiti bežično sa Croduino Basic2? Ako da sto bi za takav bezicni spoj jos trebalo naruciti ili bi to vi mogli napraviti? Namjera mi je da platim pouzećem. U vrijeme kada poštar dolazi ja sam na poslu pa Vas molim da paket isporuče na ovu adresu gdje radim: [name removed] COLSHIP d.o.o. Trg [name removed] Koblera 2 [address removed]
Originally submitted via email support on 15 December 2016. Migrated to the forum for community visibility.
The CSP SENSE set includes a 433MHz RF module that can wirelessly connect two microcontrollers. This module provides single-channel, one-directional communication. Depending on the amount and speed of data transmission, you could implement this with Croduino NOVA (from the IoT set) and Croduino Basic2 (from the Hobby set). With Croduino NOVA you can also connect wirelessly to the network and send data to a server.
U CSP Sense nalazi se 433Hz RF modul kojim možete bežično povezati dva mikrokontrolera. Ovaj modul omogućuje jednokanalnu komunikaciju, u jednom smijeru. Ovisno o količini i brzini slanja podataka mogli biste ovo izvesti s Croduino NOVA (IoT set) i Croduino Basic2 (Hobby set). S Croduino NOVA pločicom bežično se možete povezati na net i slati podatke na neki server.
Attachment omitted in migration: Ponuda COLSHIP_d_o_o__141_2016.pdf
