Can an ultrasonic proximity sensor be connected to the Croduino NOVA, which has built-in WiFi capability? I assume it should work, but I want to confirm before ordering components.
zanima me može li se spojiti ultrazvučni senzor blizine na croduino nova koji sam po sebi ima mogućnost Wifi veze?
Pretpostavljam da može ali želim biti siguran prije nego naručim komponente. Hvala
Lp, [name removed]
Originally submitted via email support on 6 May 2017. Migrated to the forum for community visibility.
You can use it without issues with the Croduino NOVA. For triggering and reading, you can use the same code as described here: https://e-radionica.com/hr/blog/2015/08/19/kkm-ultrazvucni-modul-hc-sr04/ Just select different pins - any GPIO will do the job.
bez probleme ga koristite s Croduino Nova. Za triganje i očitanje možete koristiti isti kod kao ovdje: https://e-radionica.com/hr/blog/2015/08/19/kkm-ultrazvucni-modul-hc-sr04/
Samo odaberite druge pinove, bilo koji GPIO će obaviti posao.
