Controlling 6V water pump from 3.3V micro:bit signal
I want to build an automatic plant watering system. I have a micro:bit running at 3.3V, a humidity sensor at 3V, and a 6V water pump. The micro:bit will send a signal to the pump, but they don’t have the same operating voltage. What else do I need?
Pozz,Zelim napraviti set koji vrsi automatsko zalijevanje biljaka.
Imam microbit 3,3V,senzor vlaznosti 3V i crpku za vodu od 6V.Sto mi je jos potrebno buduci da microbit salje signal crpki,posto nemaju isti radni napon?
Originally submitted via email support on 9 March 2018. Migrated to the forum for community visibility.
You only need a MOSFET transistor to activate the pump. See the IRF540N MOSFET transistor and how to use it as a switch: the connection method is identical for micro:bit.
trebate samo jedan MOSFET tranzistor kako biste mogli aktivirati pumpu: https://e-radionica.com/hr/irf540n-mosfet-tranzistor.html
ovdje pogledajte kako ga koristiti: https://e-radionica.com/hr/blog/2017/12/10/kako-koristiti-mosfet-kao-prekidac/
(identično je i za micro:bit)
