I received a Croduino Basic 2 but have been unable to connect it to a computer for two days. I followed the instructions provided on the website and with the Croduino. I downloaded the drivers, installed Arduino IDE, and configured the settings in the application as follows:
Board: Arduino Nano
Processor: ATmega328
Port: COM3 (which I verified in Device Manager is connected to the Croduino)
However, I kept getting this error:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x68
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x68
I tried the same on another computer with a different Windows version, and when it didn’t work there either, I tried installing an older Arduino IDE, but I still couldn’t upload the program to the board.
I then tried installing Arduino IDE on Linux, but the program still produced the same error.
I tried changing the USB cable but that didn’t help either.
Prekjucer sam dobio Croduino basic 2, ali vec 2 dana ga ne mogu povezati s racunalom. Pratio sam upute koje ste dali na stranici i uz Croduino. Skinuo sam drivere, instalirao Arduino IDE i namijestio postavke u aplikaciji ovako:
Board: Arduino Nano
i Port: COM3 (koji sam u device menager-u vidio da je spojen s Croduinom)
Ali i dalje mi je izbacivalo ovaj error:
"avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x68"
Onda sam to isto probao na drugom racunalu sa drugim windowsima, te nakon sto ni tamo nije radilo probao sam instalirati stariji Arduino IDE, ali i dalje nisam uspio upload-ati program na plocicu.
Nakon toga sam probao instalirati Arduino IDE na Linuxu, ali program je i dalje izbacivao istu gresku.
Probao sam promijeniti USB kabel ali ni to nije radilo.
Vise ne znam sta bih pokusao, mislio sam da ce ovo biti puno jednostavnije za napraviti. Ako ste se susreli sa slicnim problemom molio bih vas da mi pomognete.
Originally submitted via email support on 5 April 2017. Migrated to the forum for community visibility.
