Croduino Basic 2 avrdude stk500_getsync() not in sync errors on upload
I’m having problems with Croduino Basic 2. Whenever I try to install it (Windows), I get errors during upload. I’ve made the recommended settings from your website and installed the required driver. Can you advise me how to solve this problem?
Here are the error messages:
Arduino: 1.6.5 (Windows XP), Board: “Arduino Nano, ATmega328”
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x60
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Poštovani,imam probleme s Croduino Basic 2.Gdje god ga instaliram (Win) javlja pogreške kod uploadanjaNapravio sam one postavke koje preoručujete na stranici i instalirao sam traženi drajver.Možete li mi dati savjet kako da riješim problem.?s poštovanjem
Ovo su poruke o pgrešcI:
This report would have more information with
“Show verbose output during compilation”
enabled in File > Preferences.
From: Tiho [name removed] (Generalni kontakt: e-radionica.com)
To: [name removed]
Sent: Monday, October 24, 2016 10:39 AM
table # body .filtered99999
Originally submitted via the contact form on soldered.com on 21 March 2017. Migrated to the forum for community visibility.
The error indicates a communication problem between the OS and the USB to UART bridge. Try the following: verify that you have selected the correct COM port assigned to the Croduino. Try uploading with a different USB cable.
error prikazuje grešku u komunikaciji između OS i USB to UART bridga.
Probajte sljedeće: provjerite jeste li odabrali COM port koji je dodjeljen Croduinu. Probajte napraviti upload s drugim USB kabelom.
