I received a Croduino Basic 2 board and couldn’t connect it to my computer. I sent it back and received a replacement, but it has the same problem. When I connect it, I get a USB device not recognized message. The driver is installed for Windows: Windows driver package Silicon Laboratories Ports (03/19/2014 6.7.0.0).
OS is Windows 7 Ultimate 64-bit. I tried connecting the board to several laptops (all with the same OS) and replaced the USB cable but without success. When I connect the board to the laptop, the blue power LED lights constantly, and the orange LED at pin 13 flashes briefly when connected and then stays on after a few seconds.
I’m sending you a photo - I noticed small solder balls on the legs of one component (CP 2102).
Dobar dan,
Evo ja sam stigao doma pa vam pisem da rijesimo problem sa croduino basic 2 plocicom. Samo kratko: prvi put kad sam dobio plocicu nisam je uspio spojiti sa kompjuterom. Plocicu sam poslao vama nazad i dobio sam zamjensku koja mi ima isti problem. Kada ju prikljucim daje mi poruku USB device not recognized. Driver je instaliran za windows, windows driver package silicone laboratories (slabenm) ports (03/19/2014 6.7.0.0).
OS je windows 7 ultimate 64 bit. Pokusao sam spojiti plocicu na vise laptopa (svi imaju isti OS) i zamijenio sam usb kabel ali bez uspjeha. Kada spojim plocicu na laptop plava ledica power svijetli stalno, narancasta ledica kod pina 13 sasvijetli jedanput kratko kada se spoji i onda nakon par sekundi flasha stalno.
Saljem vam i sliku, primjetio sam na jednom elementu (cp 2102) na nozicama male kuglice od lema ako vam to nesto indicira.
Molio bi vas za pomoc, pozdrav,
Andrija
Originally submitted via the contact form on soldered.com on 11 October 2017. Migrated to the forum for community visibility.
