Does Croduino Basic support powering via a 9V battery with a mini USB to battery connector?
Hvala
Originally submitted via email support on 4 November 2021. Migrated to the forum for community visibility.
Hvala
Currently available is a 9V battery clip with open wires at the end. You can solder it to something or use it with an experimental breadboard by inserting the wires.
If you plan to power Croduino with more than 5V, use the VIN pin. When Croduino is powered via USB connector it needs stable 5V, and for higher voltages use the VIN pin.
Možete ga zalemiti na nešto ili pak koristiti u kombinaciji s exsperimentalnom pločicom u koju samo ubodete žice. Svakako ako planirate napajati Croduino s više od 5V trebate koristiti VIN pin, Kada se Croduino napaja putem USB konektora treba imati stabilnih 5V, a za sve veće napone treba koristiti VIN pin.
If I connect an easyC adapter to Croduino Basic3 and use only the red and black wires (the other two are not needed?), can I connect directly to a 9V battery?
Hvala vam na odgovoru. Ako se spojim easyc adapterom na Croduino Basic3 onda koristim samo crvenu i crnu žicu (ostale dvije nisu potrebne?) i na taj način se mogu spojiti direktno na bateriju od
9 V ?
Hvala
No, the easyC connector only supports 3.3V. For 9V you must use the VIN pin as explained previously.
nažalost ne, na easyC smijete spojiti samo napon od 3.3V i niti koji drugi. Za 9V morate koristiti VIN pin kako Vam pojašnjava kolega u prijašnjem emailu.
