Croduino Basic code simulation and output monitoring software
Is there free simulation software available where I can test code and monitor the state of digital and analog outputs as well as variables changing within the algorithm? The goal is to simulate the code to avoid damaging the board and to avoid having to repeatedly upload programs to it.
Dobar dan,
jedno pitanje da li postoji koji free software na kojem bi se mogla izvesti simulacija koda te da se mogu pratiti stanja analognih i digitalnih izlaza kako i varijable koje se mijenjaju unutar samoga algoritna. Shvrha simulacije da se izmbjegne oštećenje same pločice i da se netreba uzastopno uplodati program.
Originally submitted via email support on 5 November 2015. Migrated to the forum for community visibility.
The Arduino IDE, which works with the Croduino Basic board (14 digital and 8 analog inputs), has an integrated Serial Monitor that displays readings. In this case, you would need to limit the inputs to maximum 5V. You can also write a simple script to do the same. We have a tutorial on Python on our site (http://e-radionica.com/hr/blog/2015/09/22/croduino-i-python/) that reads the serial port. We are planning to add the same for Visual Basic IDE soon, so you can count on that as well.
koristite li/planirate koristiti neki poseban kontroler za navedeno?
Software Arduino IDE, na kojem može raditi naša pločica Croduino Basic(14 digitalnih i 8 analognih ulaza), ima integrirani Serial Monitor koji prikazuje očitanja. U tom slučaju ulaze bi trebalo ograničiti na max5V.
Također, možete sami složiti malu skriptu koja bi radila isto. Na stranicama imamo tutorial za python(http://e-radionica.com/hr/blog/2015/09/22/croduino-i-python/) koja čita serijski port. Uskoro planiramo staviti isto za Visual Basic IDE, pa možete i na to računati.
