I connected a stepper motor to my Croduino Basic following the instructions. I used the stepper one Revolution program from the examples. The motor doesn’t work as it should - it should rotate one full turn to each side. Instead, the motor rotates approximately 30 degrees smoothly, then another twenty degrees with jerking, and continues this pattern always in the same direction. Do you have any experience with this and suggestions on what to do? Also, the beginner kit only came with wires with male connectors on both ends, but connecting the stepper requires male on one end and female on the other. Additionally, the tutorial shows a different module connector configuration than the one you sell. I’m also unclear about the purpose of the ON/OFF connectors next to the power connector (5-12V).
složio sam prema uputama steper motor na Croduino basic.
Koristio sam program is examples, steper one Revolution.
Ukratko stvar ne radi kako piše da bi trebala raditi (po jedan okret na svaku stranu).
Umjesto toga motor se okrene oko 30 stupanja ravnomjerno, zatim daljih
dvadesetak stupanja trzavo i tako stalno na istu stranu.
Imate li o tome kakvih iskustava i prijedloga što mi je činiti?
V. [name removed].
PS
Uz moj kit za početnike došle su samo žice za spajanje s muškim krajevima dok bi za
priključak stepera trebale sa muškim na jednom i ženskim na drugom mkraju. Osim toga
u tutorialu je slika spajanja drugačije izvedbe modula od one koju prodajete.
Takodjer nije mi jasno čemu služe ON/OFF priključci kraj priključka za napajanje
(5-12V).
Originally submitted via email support on 10 December 2015. Migrated to the forum for community visibility.
