Croduino Basic V1.0 FTDI FT232R controller not recognized
I have a question about incorrect drivers bricking my Croduino Basic V1.0. I’m getting an error that the device is not responding - specifically its FTDI FT232R controller. I found a way to fix it online but I’m not sure if it applies to my case. Could you send me the values for MProg-Multi Device EEPROM Programmer if needed? I can provide screenshots if necessary. I need this device for a competition.
Pozdrav, imam pitanje znači zbog krivih drivera mi se bricko croduino basic V1.0 greška kaže da uređaj ne reagira odnosno njegov kontroler FTDI FT232R. Na internetu sam našao način kako ga popravit ali nisam siguran je li je to tako i u mom slučaju pa bi vas molio jer mi mozete posalti vrijednosti za MProg-Multi Device EEPROM Programmer ako treba priložit ću slike zaslona.Uređaj je potreban za natjecanje. Hvala!
Originally submitted via email support on 8 February 2016. Migrated to the forum for community visibility.
Are you using Windows OS? If I understand correctly, the fastest solution would be to uninstall the drivers - https://e-radionica.com/hr/blog/2015/08/19/kako-deinstalirati-ftdi-drivere/
Windows can have issues when assigning virtual ports, it would be good to clean/reset COM ports as well - https://e-radionica.com/hr/blog/2015/08/28/kako-ocistitiresetirati-com-portove/
If I’m wrong, please send screenshots so we can resolve your problem quickly.
Koristiš Windows OS?
Ako sam sve dobro pohvatao, najbrže bi bilo kada bi deinstalirao drivere - https://e-radionica.com/hr/blog/2015/08/19/kako-deinstalirati-ftdi-drivere/
Windows se zna glupirati kada treba dodjeliti virtualne portove, ne bi bilo loše - https://e-radionica.com/hr/blog/2015/08/28/kako-ocistitiresetirati-com-portove/
Ako sam u krivu, molim te pošalji screenove, da čim prije rješimo tvoj problem.
I tried what you suggested but it didn’t work.
The first screenshot shows default settings for Product ID and uses old drivers, and in the second the Product ID has changed to the same value as when I first connected the device and uses new drivers.
I checked the configuration and nothing else was modified.
I also tested in a virtual machine with Linux OS and the same error appears.
Pokušao sam što ste mi predložili, ali nije uspjelo.
prva prikazuje default postavke za Product ID i koristi stare drivere, a u drugoj je Product ID promjenjen na istu valutu kao što je bilo kada sam prvi puta spojio uređaj i koristi nove drivere
i pogledao konfiguraciju ostalo nije uređivano
Testirao sami u virtualnoj mašini sa Linux OS ista greška se javlja
Attachment omitted in migration: 2016-02-09 14_57_03-.png
Attachment omitted in migration: 2016-02-09 15_17_07-MProg - Multi Device EEPROM Programmer ( Edit Mode ).png
That’s right, the problem is with the Product ID. One batch of our FTDI chips (50 or 100 units) that we purchased from a third-party source turned out to be counterfeit. When anyone with such a chip connects it to a computer with drivers newer than 2.12.00, the Product ID of that FTDI chip changes to 0000 and it becomes practically unusable.
The solution is: uninstall the drivers and reinstall a version older than 2.12.00. Everything will work. Don’t try to modify the PID, it will work with 0000.
You can find more solutions here: http://www.rei-labs.net/changing-ftdi-pid/
tako je, problem je s Product ID-em, jedna naša serija FTDI chipova(50 ili 100 komada) koje smo kupili iz trećeg izvora je na kraju ispala neoriginalna, pa svima koji takav chip spoje na računalo s driverima većim od 2.12.00 - PID toga FTDI-ja se mijenja na 0000 i on je praktički neupotrebljiv.
Dakle, savjet je: deinstalirati drivere i ponovno instalirati verziju manju od 2.12.00. Sve će raditi. Ne treba dirati ni PID, sa 0000 će raditi.
Više rješenja možete pronaći ovdje: http://www.rei-labs.net/changing-ftdi-pid/
Usput, kada se kupili taj Croduino od nas?
