Croduino Basic vs Basic2 differences for beginners
Which Croduino board is better: Croduino Basic or Croduino Basic2? What are the differences between them? Which Croduino board is better for a beginner, and where can I download the setup for programming Croduino boards?
Pozdrav, koja je bolja CROduino pločica? Koja je CROduino pločica bolja za početnika, gdje preuzeti setup za programiranje CROduino pločica?
Originally submitted via email support on 25 February 2017. Migrated to the forum for community visibility.
Basic and Basic2 use the same microcontroller, so they are essentially identical. The difference is in the USB to UART bridge, which as a beginner should not concern you. We recommend the more affordable Basic2 version. More information about the comparison can be found here: https://e-radionica.com/hr/blog/2015/10/11/novi-croduino-je-tu-croduino-basic2/ The article will guide you to other resources where you can find answers on how to get started with Croduino. You can also post an inquiry here if you get stuck anywhere.
hvala na interesiranju za Croduino pločice.
Basic i Basic2 koriste isti mikrokonteroler pa su zapravo i iste. Razlika je u USB to UART bridgu što Vas kao početnika ne bi trebalo brinuti. Preporućamo jeftiniju Basic2 verziju. Više o usporedbi pročitajte ovdje: https://e-radionica.com/hr/blog/2015/10/11/novi-croduino-je-tu-croduino-basic2/
Ćlanak će Vas odvesti na druge gdje je, između ostalog, odgovor na pitanje što i kako započeti s Croduinom. Također, uvijek možete ovdje poslati upit ako zapne negdje.
Ugodan dan.
