I bought a Croduino Basic2 beginner set and from the start I cannot upload programs to the board. It worked maybe twice, but as soon as I change any timing delay, I cannot upload the program anymore. In settings I selected Arduino Duemilanove or Diecimila, it’s connected to COM3, programmer: ArduinoISP. I downloaded and installed the FTDI drivers. Every time I try to upload I get this error: avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Sometimes the board is not recognized when I connect it to the computer (I think the board might have arrived damaged - I got the set this morning). How can I fix this?
PS: When I connect to the computer, a blue LED lights up and an orange LED flashes briefly then turns off and doesn’t light again until I press the RESET button. Sometimes a red LED blinks along with the blue one.
kupio sam kod vas CRODUINO SET ZA POČETNIKE (CSP) HOBBY i od samoga početka
ne mogu prebaciti program na pločicu. Uspjelo je možda 2 puta,ali čim
promijenim vremensko čekanje više nikako ne mogu uploadti programa na
pločicu. U postavkama sam odabrao Arduino Duemilanove or Diecimila, spojen
mi je na port COM3, programator: ArduinoISP. Skinuo sam i FTDI drivere i
instalirao ih. Kod svakog skidanja programa na pločicu dobijem ovakvu
poruku: avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00 .
Ponekad ne mogu prepoznati da sam spojio pločicu na računalo (mislim da je
i pločica došla oštećena, danas ujutro sam dobio taj set). Kako otkloniti
tu smetnju?
PS
Zaboravio sam reći da kada se spoji na računalo, svijetli plava LED i na
trenutak zasviejtli narančasta LED pa se potom izgasi i više se ne pali dok
se ne pritisne RESET tipka. Ponekad uz plavu zna blinkati i crvena LED.
Originally submitted via email support on 25 January 2018. Migrated to the forum for community visibility.
