I’m a final year student working on my diploma thesis. I’d like to use one of your Arduino models for the project, which involves creating a system in CAD software and then physically building and programming the components. Do you have a CAD model for CRODUINO BASIC2 that I could use to create a more accurate replica of the actual board?
student sam na zadnjoj godini fakulteta. Prilikom izrade diplomskog rada rado bih koristio jedan od vaših arduino modela. Diplomski rad sastoji se od izrade sustava u CAD softveru i kasnije fizičku izradu i programiranje zadanih komponenti. Ako imate CAD model za CRODUINO BASIC2 bilo bi mi drago da mi ga pošaljete kako bih imao što vjerniju repliku stvarnog stanja.
Originally submitted via email support on 30 March 2021. Migrated to the forum for community visibility.
The Croduino Basic2 board is open hardware. You can find its design files in the Github repository: GitHub - SolderedElectronics/Croduino-Basic2-Eagle-Files: Cadsoft Eagle files for Croduino Basic2 - Arduino compatible board · GitHub
hvala Vam na upitu.
Croduino Basic2 pločica je open hardware, a njene datoteke možete pronaći unutar Github repozitorija: GitHub - SolderedElectronics/Croduino-Basic2-Eagle-Files: Cadsoft Eagle files for Croduino Basic2 - Arduino compatible board · GitHub
Thank you for the link, which will be useful. However, that’s not exactly what I was looking for. There are certain Arduino board models and other electronic components available online that provide more detailed CAD models for accurate representation. I’ve attached an image and a link to one such component, an L298N driver. Link: https://grabcad.com/library/h-bridge-high-detail-1 Do you have a similar detailed CAD model of your Croduino in STEP format or any other format? Creating such a model takes considerable time, so it’s possible you don’t have one, but it’s worth asking. Could you also tell me the height of the Croduino Basic board? The website only lists the length and width.
hvala Vam na odgovoru. Link koji ste mi poslali će mi također biti koristan, ali to nije ono što me konkretno zanimalo.
Na internetu postoje određeni modeli arduino pločica i ostalih elektroničkih komponenti koji služe za vjerniji prikaz CAD modela. U prilogu Vam šaljem sliku i link na jednu takvu komponentu, L298N driver.
Imate li možda takav ili sličan CAD model Vašeg Croduina u step (ili bilokojem drugom) formatu? Izrada takvog modela iziskuje dosta vremena pa je moguće da ga nemate, ali vrijedi pokušati. Možete li mi reći koja je visina Croduino Basic pločice s obzirom da je na stranici navedena samo duljina i širina?
Attachment omitted in migration: L298N.png
Unfortunately, we don’t have detailed CAD models like that for our boards. The height of the Croduino Basic board is approximately 10.61mm.
hvala Vam na brzom odgovoru.
Takve modele naših pločica nažalost nemamo.
Visina Croduino Basic pločica je cca 10.61mm.
