Croduino Basic2 light switch system setup and power requirements
I’m setting up a light switch system using Croduino Basic2 and some components. I need help with installation links and resources.
Evo javljam se prema dogovoru vezano za pomoć oko instalacije sustava za svjetlo kao prekidač kupio sam komponentne,rekli ste da vam se javim oko linkova i ostaloga.
Originally submitted via email support on 3 March 2018. Migrated to the forum for community visibility.
Here are the resources you’ll need:
Croduino Basic2 is the microcontroller board you’ve purchased: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
You’ll need drivers for the Croduino Basic2 board: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
You need software for programming: https://e-radionica.com/hr/blog/2015/08/19/instalacija-arduino-ide/
You’ll need to learn the basic concepts of programming the board: https://e-radionica.com/hr/blog/2015/11/26/arduino-ide-inputoutput/
Also available as video: https://www.youtube.com/watch?v=xhEWPBnHRGU&t=1s
More information if interested: https://e-radionica.com/hr/blog/2015/10/08/sto-je-arduino-i-croduino/
And the sound detector module: https://e-radionica.com/hr/blog/2015/08/19/kkm-modul-detektor-zvuka-2/
slijede linkovi i kratki opisi. Javite ako nešto bude falilo.
Croduino Basic2 je mikrokontrolerska pločica koju ste uzeli: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Trebat ćete drivere za Croduino Basic2 pločicu koju ste kupili: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
trebate software za programiranje: https://e-radionica.com/hr/blog/2015/08/19/instalacija-arduino-ide/
trebat ćete savladati osnovne pojmove vezane uz programiranje pločice: https://e-radionica.com/hr/blog/2015/11/26/arduino-ide-inputoutput/
može i u obliku videa: https://www.youtube.com/watch?v=xhEWPBnHRGU&t=1s
više o svemu(ukoliko Vam je zanimljivo): https://e-radionica.com/hr/blog/2015/10/08/sto-je-arduino-i-croduino/
iako izgleda puno, to u jedno poslijepodne sve skontate :slight_smile:
i ostaje detektor zvuka: https://e-radionica.com/hr/blog/2015/08/19/kkm-modul-detektor-zvuka-2/
Can the power supply be 5V for both the Croduino board and the sound detector module?
Super čim dođem doma pogledam samo jedna info ako moze napajanje moze biti od 5 v za obadve plocice modul i citac zvuka?
Yes, both can work on 5V!
Da, obe mogu raditi na 5V!
I haven’t started the project yet but I’ll need help. I have questions: can one power supply run the entire system? What is the difference between connecting to digital vs analog pins? And if I program it incorrectly, will the processor be damaged?
Hvala vam na brizi no nisma jos stigao oko projekta nista no trebat ce mi pomoc jer me zanim jedno napajanje moze da pordzi cijeli sustav_ i da na digitalno spajamo a na analogno cemu ono sluyi.. i sta ako krivo programiram dal ce se ostetiti procesor.
It depends on the power supply, but these systems don’t consume much power unless they have some form of RF communication. For this setup, something like 5V 50mA is sufficient.
Here’s a quick explanation of the difference between digital and analog: https://e-radionica.com/hr/blog/2015/10/08/sto-je-arduino-i-croduino/#Što se nalazi na Croduino plo%C4%8Dici?
More on digital: https://www.youtube.com/watch?v=oPlepGiOi_4
More on analog: https://www.youtube.com/watch?v=yPlSGZAI0LY
Nothing will be damaged by incorrect programming.
ovisi o napajanju.. al takvi sustavi ne troše puno, osim kada imaju neki oblik RF komunikacije. Tako da u ovom obliku nešto na 5V 50ak mA je sasvim dovoljno.
ovdje je brzinski objašnjena razlika između digitalnog i analognog: https://e-radionica.com/hr/blog/2015/10/08/sto-je-arduino-i-croduino/#Što se nalazi na Croduino plo%C4%8Dici?
više o digitalnome ovdje: https://www.youtube.com/watch?v=oPlepGiOi_4
više o analognome ovdje: https://www.youtube.com/watch?v=yPlSGZAI0LY
Neće se ništa oštetiti krivim programiranjem
