Croduino Basic2 schematic and SMD soldering resources
I’m interested in electronics and would like to build a board similar to the Croduino Basic2. Could you share the schematic for how you designed this board? Also, where can I learn to solder SMD components?
ja sam Nikola imam 11 godina, inače, volim sastavljati elektroničke uređaje.
Jako mi se sviđa Vaš Croduino Basic2 a ja bih htio sastaviti jednu sličnu pločicu poput te. Da li mi možete poslati shemu kako ste Vi složili tu pločicu i gdje s može u Osijeku
zalemiti SMD komponente.
Originally submitted via email support on 17 August 2023. Migrated to the forum for community visibility.
Electronics is a great field where you can build almost anything if you develop the right skills in both hardware and software.
The schematic for Croduino Basic2 is available. Our newer Arduino-compatible boards are called Dasduino. See Dasduino Core here: https://soldered.com/product/dasduino-core-with-female-headers/
All our hardware design files are available on GitHub because everything we do is open source: GitHub - SolderedElectronics/Dasduino-CORE-hardware-design: Hardware design, BOM, gerbers and 3D files for Dasduino-CORE designed by Soldered Electronics. · GitHub
We use KiCad for design, which is a free open source program for creating schematics and PCBs that you can download here: https://www.kicad.org/
If you install KiCad and clone the Dasduino CORE hardware design repository from GitHub, you can open the schematic and board layout to study how everything works.
Dasduino and Croduino boards are 2-layer designs.
Unfortunately, you cannot solder components with us since we only do serial production for clients. However, there’s something to look forward to: a Dasduino Solder kit will be coming out soon, and you’ll be able to solder your own Dasduino!
Drago mi je da te zanima elektronika. To je super područije u kojem, ako si vješt, možeš izmisliti doslovce što god hoćeš. Pogotovo ako znaš hardver i softver.
U prilogu ovog maila ti šaljem Shemu Croduino Basic 2. Naše novije Arduino-kompatible pločice se zovu Dasduino.
Evo linka za Dasduino Core: https://soldered.com/product/dasduino-core-with-female-headers/
Za sve naše proizvode možeš na našem GitHub repozitoriju pronaći datoteke za Hardver, jer je sve što radimo open source: GitHub - SolderedElectronics/Dasduino-CORE-hardware-design: Hardware design, BOM, gerbers and 3D files for Dasduino-CORE designed by Soldered Electronics. · GitHub
Za Circuitmaker nisam siguran, mi koristimo KiCad. To je besplatan program (isto open source) za izradu shema i pločica koji možeš preuzeti ovdje: https://www.kicad.org/
Ako instaliraš KiCad i skineš ovaj github repozitorij za Dasduino CORE hardware design, možeš otvoriti shemu i dizjan pločice i proučiti kako sve radi.
Dasduino/Croduino pločice su 2 sloja.
Zalemiti komponente na žalost ne možeš kod nas jer mi radimo samo serijsku proizvodnju za klijente.
PS. Imam za tebe malu insider informaciju: uskoro će izaći Dasduino Solder kit te ćeš moći zalemiti svoj vlastiti Dasduino!
Attachment omitted in migration: Basic2.pdf
