Croduino BASIC2 vs BASIC3 differences and fuse protection
I’ve been looking at the Croduino BASIC2 and BASIC3. I’m interested in whether the only difference between them is “fuse protection” and whether that refers to pin protection.
Proučavao sam Croduino basic 2 i 3.
Zanima me da li je jedina razlika između njih “fuse protection” i da li se to odnosi na zaštitu pinova?
Originally submitted via email support on 9 January 2020. Migrated to the forum for community visibility.
The difference between the BASIC2 and BASIC3 boards is in the easyC connector and the different UART chip. There is no actual protection for the pins themselves because they are routed directly from the microcontroller. Both boards have a polyfuse that prevents current greater than 500mA from passing through and cuts off power to the Croduino board.
hvala Vam na upitu.
Razlika između Basic2 i Basic3 pločice je u easyC konektoru te različitom UART čipu. Sama zaštita za pinove ne postoji jer su direktno izvedeni sa mikroupravljača. Obje pločice na sebi imaju polyfuse (osigurač) koji onemogućava prolazak struje veće od 500mA te prekida napajanje same Croduino pločice.
