Croduino compatibility with ThingSpeak
Is Croduino compatible with ThingSpeak (https://thingspeak.com/)?
Dobar dan,
moje pitanje je da li je vas croduino kompaktibilan sa ovom stranicom:
Originally submitted via email support on 5 December 2016. Migrated to the forum for community visibility.
Croduino will work with ThingSpeak without problems, but you will need additional hardware to connect to the network, such as an Ethernet shield or WiFi module. We recommend Croduino NOVA, which has built-in WiFi. With it, implementing things like this will be much simpler because you can program it directly from Arduino and everything is already connected.
Croduino će raditi s Thingspeak-om bez problema, ali trebate još neki hardware za povezivanje na mrežu, kao tipa Ethernet shield ili Wifi modul.
Preporučamo Croduino NOVA koji na sebi ima ugrađen WiFi, s njime će implementacija na ovakve stvari biti daleko jednostavnija jer se programira direktno iz Arduina i sve ima spojeno na sebi.
