Croduino: controlling LED outputs from a computer program
I want to know if it’s possible to run a program on a computer that lets a user select a product, and then use your electronics to turn on specific LED lighting accordingly. In other words, can I control outputs through the computer as inputs?
zanima me da li je izvedivo s ovim proizvodima da se na računalu izvodi neki program koji u ovisnosti o želji korisnika odabire neku proizvod i onda da se preko ove Vaše elektronike pali točno određena LED rasvjeta?
Dakle pitanje je da li je moguće odabire nekog izlaza kontrolirati preko računala kao ulaz
Hvala
Originally submitted via email support on 14 September 2016. Migrated to the forum for community visibility.
This is possible using the Croduino. If you only need to control LEDs from a computer, that’s not a problem. If you also need a graphical interface, it becomes more complex, but it’s still achievable. You’ll find many examples online for how to do this with Arduino, and anything you can do with Arduino, you can do with Croduino. This video explains the operating principle of RGB LEDs which would be suitable for your application: https://www.youtube.com/watch?v=9rXEejtOqmE
moguće je odraditi navedeno koristeći naš Croduino. Ako bi Vam trebala samo kontrola LEDica preko računala, to nije nekakav problem. Ako trebate još nekakvo grafičko sučelje, stvar se malo komplicira, ali opet je ostvarivo.
Na internetu imate mnogo primjera kako to odraditi koristeći Arduino, a sve što možete s Arduinom, možete i s Croduinom. U ovom videu imate objašnjen princip rada RGB LEDica koje bi odgovarale Vašoj primjeni: https://www.youtube.com/watch?v=9rXEejtOqmE
Ako trebate savjete i dalje, slobodno se javite s pitanjima
