Croduino Damba pinout guide and unmarked pins
I need the pinout for the Croduino Damba board. The link on your website is broken (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics) and the markings on the board are not visible. In particular, in the second inner row only marking 13 is visible.
Molio bih Vas ako je moguće da mi pošaljete pinout za Croduino Damba pločicu. Link na Vašoj stranici je nepostojeći (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics) a na pločici su oznake nevidljive. Pogotovo u drugom, unutrašnjem redu gdje je vidljiva samo oznaka 13.
Originally submitted via email support on 7 December 2015. Migrated to the forum for community visibility.
The pinout can be found at this link: https://www.facebook.com/eradionica/photos/pb. . . ./ /?type=3&theater
The row with marking 13 has no other markings. “13” refers to pin 13 of Croduino (SCK), followed by pin 12 of Croduino (MISO), and so on.
isprike prebacujemo stranicu na SSL pa imamo problema s linkovima.
Pinout možete vidjeti na ovom linku: https://www.facebook.com/eradionica/photos/pb. . . ./ /?type=3&theater
Inače, red s oznakom 13 ni nema drugih oznaka. “13” se odnosi na pin 13 croduina (SCK), sljedeći bi bio pin 12 Croduina (MISO) i td.
