Do you have any documentation for the Ethernet shield? If not, which library do you recommend? Also, can you supply a Croduino with all female connectors facing downward so I can plug it into a custom interface board below it?
Da li mi molim vas možete javiti da li imate kakav KKM o Ethernet shieldu, ako nemate koji library preporučujete?
Također me interesira da li možete isporučiti takav Croduino da su svi njegovi ženski konektori okrenuti prema dolje (kako bi ga mogao koristiti tako da ga „zapiknem“ u donju novo-dizajniranu interface pločicu)?
Hvala vam na pomoći!
Originally submitted via the contact form on soldered.com on 11 December 2017. Migrated to the forum for community visibility.
For the Ethernet shield, I recommend the official Arduino library: https://www.arduino.cc/en/Reference/Ethernet
Note that if you use an Ethernet shield with Croduino, you must connect through the ICSP connector: How to wire and test your Arduino + Ethernet Shield | KinectDuino
We can supply Croduino without headers so you can solder them as needed, or we can solder the headers to the opposite side if you prefer.
isprike na malo zakašnjelom odgovoru.
Za Ethernet shield preporučam službeni Arduino library: https://www.arduino.cc/en/Reference/Ethernet
napominjem da ako koristite Ethernet shield + Croduino, konekciju morate izvesti s ICSP konektora
Možemo isporučiti Croduino i bez headera pa možete zalemiti na način koji Vam odgovara, ali nije niti nama problem ukoliko želite da headere zalemimo na drugu stranu.
Can you also help with SD cards – which one should I use and do you have documentation or a library for it? I’ll let you know about the Croduino order separately.
Hvala vam puno na odgovorima/preporukama. Da li bi mi još mogli pomoći oko SD kartice – koju koristiti i da li imate KKM (ili library)?!
Za Croduino vam još javim (trebati će mi oko 10-12 kom.). LP,
You can use an SD card with the Ethernet shield or as a separate module – the usage and wiring is identical. We don’t have documentation unfortunately (it’s on our list!), but we showed SD card usage in a Croduino lesson on SPI: https://www.youtube.com/watch?v=BERtPDVsc1g
No problem with the Croduino order, just let us know the quantity.
možete koristiti SD karticu s Ethernet shielda ili kao poseban modul jer je korištenje i povezivanje identično, nažalost KKM nemamo(stavljeno na popis!:)), ali pokazali smo korištenje u Croduino lekciji s SPI: https://www.youtube.com/watch?v=BERtPDVsc1g Nema problema za Croduino, samo javite.
