I need documentation for the Croduino miniNOVA and CP2102 USB UART.
Specifically, I’m looking for:
- Pinout of the board (in any format)
- Connection diagram for the CP2102 USB adapter to the board for programming
- Any necessary changes to Arduino IDE settings before programming
I also need recommendations for:
- A protected Li-ion charger
- Uninterruptible power supply for miniNOVA (principle: can be kept powered and charging, and continues to work on battery when power is cut)
- Battery that can keep miniNOVA alive for one or two days in WiFi client mode as an MQTT agent
- An IP65 enclosure that could store the battery, charger, board power supply, and the board itself
- Do you offer a load cell amplifier like the “SparkFun Load Cell Amplifier - HX711”?
We plan to use the miniNOVA board in a telemetry project for racing vehicles on track during races. The board will have no additional current loads besides the WiFi chip consumption for communication.
Možete li proslijediti nešto ili sve od dokumentacije za CRODUINO miniNOVA i CP2102 USB UART? Konkretno me zanima : - pinout pločice ( može u bilo kojem formatu ) - shema spajanja cp2102 usb adaptera na pločicu u svrhu programiranja iste. - eventualne izmjene u postavkama Arduino IDE prije programiranja ? Treba mi i preporuka za: - punjač li ion baterije sa zaštitom - besprekidno napajanje mininove ( princip da se može držati na izvoru napajanja i puniti, a po prekidu napajanja da nastavi raditi na bateriji ) - baterja koja miniNovu može održavati na životu dan dva u wifi client modu kao mqtt agenta… - preporuka za ip65 kućište koje bi moglo skladištiti bateriju, punjač, napajanja pločice i samu pločicu Amplifier - HX711" ? MiniNOVA pločicu planiramo koristiti u projektu za telemetriju trkaćih vozila na stazi tokom utrka. Pločica osim potrošnje samog WiFi čipa za komunikaciju neće imati dodatna strujna opterećenja.
Originally submitted via email support on 12 October 2017. Migrated to the forum for community visibility.
