Croduino not recognized on Windows 7, Power Surge Alert
Is it possible you made an error when manufacturing the Croduino? I’m getting an error when I connect the Croduino to my laptop. I’ve attached a screenshot.
Postoji li mogučnost da ste napravili neku grešku prilikom izrade Croduina? U prilogu sam vam poslala sliku što mi se javlja kad spojim Croduino na laptop.
Originally submitted via the contact form on soldered.com on 7 December 2015. Migrated to the forum for community visibility.
Which OS are you using? Some operating systems only provide 500mA per port, which is what the Croduino Basic requires. If you have other devices connected to the hub, it won’t get enough power and the OS won’t recognize it.
Try connecting the Croduino board to a different port. There’s also a possibility this is a Power Surge problem - we can send you instructions for your OS version.
koji OS koristite? Pojedini dozvoljavaju samo 500mA po portu koliko je i je potrebno za Croduino Basic. Tako da, ako imate još nešto spojeno na hubu neće dobiti dovoljno struje, te ga OS ne prepoznaje.
Probajte spojiti Croduino pločicu u neki drugi port. Postoji i mogućnost da se rješi problem Power Surge problem, poslati ćemo Vam upustva za Vašu verziju OSa.
I’m using Windows 7. I’ve tried connecting it to different ports and it wasn’t recognized on any of them.
Koristim Windows 7. Probala sam ga spojiti u druge portove i u nijednom ga nije prepoznao.
It wasn’t recognized on the other ports, or did you get a Power Surge Alert?
Have you installed the CP2102 drivers for Windows 7? (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics)
You can resolve Power Surge issues using: power surge on usb hub port windows 7 pc - Microsoft Q&A
na drugim portovima ga nije prepoznao ili se pojavio Power Surge Alert?
Jeste li instalirali Cp2102 drivere za Win7(Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics)?
Power Surge možete rješiti pomoću: power surge on usb hub port windows 7 pc - Microsoft Q&A
