I have some questions about the Croduino Nova 2 I purchased a few weeks ago:
The labels on the board for inputs and outputs do not match the labels on the included leaflet. Which ones are correct?
Are there any difficulties programming from Windows 10?
I tried using your code called “tipkalo” (button) as an activator on the Nova 2 board. When I define GPIO2 as “led” and GPIO12 as “tipkalo” everything works as described. However, when I swap them and define GPIO12 as “led” and GPIO2 as “tipkalo”, with the appropriate rewiring on the breadboard, it does not work. I tried combinations with GPIO12 and GPIO14. Both combinations work as led and as tipkalo. Are there any limitations with defining which are inputs and which are outputs?
Molim Vas par objašnjenja vezano uz Nova 2 koju sam kupio prije
par tjedana:
- Oznake na pločici za ulaze i izlaze ne odgovaraju oznakama na
priloženom letku. Koje su prave? - Postoje li koje poteškoće za programiranje iz Windovs 10
programa? - Pokušao sam koristiti na Nova 2 pločici Vaš kod pod nazivom
tipkalo kao aktivator. Kada GPIO2 definiram kao “led”, a GPIO 12
kao “tipkalo” sve radi kako je opisano. Ukoliko zamjenim te
definiram GPIO12 kalo “led”, a GPIO2 kao “tipkalo”, naravno uz
odgovarajuće prespajanje na probnoj pločici to ne radi. Pokušao
sam kombinacije sa GPIO 12 i 14. Radi u obje kombinacije kao led i
kao tipkolo. Postoje li kakva ograničenja sa definiranjem koji su
ulazi, a koji su izlazi?
Originally submitted via email support on 3 April 2020. Migrated to the forum for community visibility.
