Croduino Nova 2 power supply recommendations for breadboard work
I’d like to experiment with your Croduino Nova 2 board on a breadboard. What power supply do you recommend? I’d prefer something I can connect directly to the breadboard. I know I could use a mobile phone charger with appropriate voltage and sufficient power, but I’d like to avoid manually cutting and soldering connectors onto USB cables. Do you have any recommendations for these situations, or is it standard to build the power solution yourself from a phone charger?
Htio bih eksperimentirati sa vasom croduino nova2 plocicom pa me zanima kakvo napajanje preporucate (eksperimentiram na breadboard-u, tako da mislim da bi najbolje bilo neko napajanje koje bi mogao spojiti direktno na breadboard) - znam da mogu uzeti neki punjac za mob koji daje odgovarajucu voltazu i ima dovoljnu snagu ali htio bih izbjeci da rucno rezem i lemim konektore na usb kabel. Da li imate nesto sto bi preporucili za takve situacije ili je uobicajeno rjesenje to da napajanje slozim sam od npr punjaca za mob?
Originally submitted via email support on 27 January 2022. Migrated to the forum for community visibility.
For working with an experimental board, I recommend the MB102 EXPERIMENTAL BOARD POWER SUPPLY (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics). With this, you don’t need to cut or solder any cables. You connect the power supply to the breadboard, and you can power the supply via USB or with an adapter to a DC connector, then run the power rails across the breadboard using wires.
hvala Vam na upitu.
Ukoliko želite raditi eksperimentalnoj pločici, predlažem Vam NAPAJANJE ZA EKSPERIMENTALNU PLOČICU MB102 (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics)
gdje ne morate nikakve kablove rezati ili lemiti. Napajanje dodate na eksperimentalnu pločicu, a napajanje do te pločice možete dovesti USB-om ili nekakvim adapterom na DC konektor te kablićima vuči napajanje po eksperimentalnoj pločici.
