Croduino NOVA as standalone WiFi access point server
What USB port type does the Croduino NOVA have - type A or type B? Also, can the Croduino NOVA be programmed as a standalone WiFi hotspot access point? I see it has an ESP8266, so I assume it can be.
Koji usb portima CRODUINO NOVA? Da li je tip a ili tip b?
Također da li je CRODUINO NOVA programibilan kao standalone wifi hotspot-access point? Vidim da ima esp8266 pa pretpostavljam da je.
Originally submitted via email support on 10 October 2017. Migrated to the forum for community visibility.
The Croduino NOVA has a micro-B USB connector (like modern Android devices). It can be programmed as a standalone access point.
Croduino NOVA na sebi ima USB konektor tipa micro-B(kao i svi moderniji Android uređaji).
Može se programirati kao standalone access point.
Ako imate još pitanja - tu smo :slight_smile:
Can you help me program the Croduino as a web server that works as an access point and hosts a web page with enabled GET requests from clients? I would appreciate it if you have any source code.
Da li mi možete pomoći s programiranjem croduina kao web server, koji radi kao AccessPoint i da na njemu dignem web page sa omogucenim get pozivima klijenata. Molio bih ako imate neki source kod. :slight_smile:
We are currently writing a tutorial for the NOVA as a server that can execute actions sent by clients using GET requests via URLs. I think it will be published in a few weeks.
upravo pišemo tutorijal za NOVU kao server koji će moći izvršavati radnje koje clienti pošalju koristeći GET preko URL-a.
Mislim da će kroz nekih tjedan dana biti objavljeno!
When will the code be ready for setting up Croduino NOVA as a server? I want to use it as a standalone server without home WiFi - essentially the Arduino NOVA as a WiFi hotspot server with a mobile app as the client.
Možete mi reći kada će kod biti gotov za postavljanje croduino nova kao server side?
Ja bi ga koristio stand-alone server bez kućnog wifi.
Znači arduino-nova kao wifi-hotspot-server i mobile app kao klijent.
It should be ready by tonight. That’s my agreement with the colleague writing the tutorial. It’s almost done. What you’re planning to build should work.
bit će do danas navečer, takav je moj dogovor s kolegom koji piše tutorijal. Skoro je gotovo.
To što planirate napraviti bi trebalo funkcionirati :slight_smile:
Here is the tutorial: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Pozdrav Tomislave, evo tutorijala: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
