I have two questions:
Following the article “Croduino Nova as a client”, you mentioned Nova as server would be next. I’m interested in how you plan to access the internet network through a router. The router doesn’t have a fixed IP. While you can reach the current IP through [method], that’s not a solution. I’ve found there are special services that enable IoT (similar to DropBox for short messages) but they require a subscription. Do you know of such a service?
“How to write your own library” - Arduino IDE doesn’t allow viewing the library code, making it impossible to fix errors live (like in .ino files). If the library is somewhat larger, this is a major difficulty. How can this be solved?
Zahvaljujem, dobio sam odgovor za ventil.
Postavljam vam dva nova pitanja :
- ispod clanka “Croduino -Nova kao klijent”.
—Najavili ste kao slijedece, Nova kao server.
Zanima me kako planirate izaci na internet mrezu preko rutera. Ruter neme fiksni IP. Do trenutacnog IP. mozese doci preko , ali to nije rjesejne. Naisao sam da postoje posebni servisi koji omogucuju IoT (nesto slicno DropBoksu sam uzivoza kratke poruke) ali uz pretplatu. Znadete li neki takav servis?
- “Kako napisati vlastiti library”
---- Arduino IDE ne omogucije prikaz koda librarya, a time nije moguce uzivo ispraviti pogresku (kao u .INO). Ako je library iole veci to je velika poteskoca. Kako to rjesiti
Unapred zahvaljujem
Originally submitted via email support on 14 November 2016. Migrated to the forum for community visibility.
