Croduino Nova NB IoT alternative with ESP8266
Does Croduino have anything similar to NB IoT? Is anyone working on that?
If you know, could you point me to where I might get an NB IoT board, or does Croduino have an alternative?
jel ima nešto slično NB IoT-u od Croduina i da li se radi nešto po tom pitanju.
Ako znate možda gdje bi mogao nabavit pločicu od NB IoT ili ako ima Croduino neku alternativu.
Hvala unaprijed!
Originally submitted via email support on 1 August 2018. Migrated to the forum for community visibility.
Croduino Nova has an ESP8266 (ESP-12) WiFi chip on board, which can be used in IoT projects.
More details about the board can be found here:
Više o samoj pločici možete pronaći na sljedećem linku: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
