I recently received a Croduino Nova board with various sensors. I also contacted you about a tutorial for a heart rate pulse module and received the requested information from PulseSensor Playground (version. 2.5.0) – World Famous Electronics llc., which I appreciate. I’m a beginner with Croduino so some of my questions may seem basic, but I’m writing a project paper about Croduino and sensors so I’d appreciate detailed and comprehensive answers.
I’ve noticed that when I run any example from the “PulseSensor Playground” group, except “GetStartedProject”, Arduino IDE shows me an error: “// out of range exit status 1, Error compiling for board Generic ESP8266 Module”. When I switch the board to Arduino/Genuino Uno and run the code on it (using Genuino Uno, not Croduino Nova), everything works normally. The difference in the codes is in the PulseSensorPlayground library which is included in all code examples except the initial one. Can I run the other examples on the Croduino Nova board? Does Croduino Nova only work correctly when I select Board “Generic ESP8266 Module” or can I select another board to use all the codes?
My goal is to collect sensor readings and use the WiFi module on Croduino Nova to send/store that data in the IoT world. I would also ask you, since I believe you’ve done something similar countless times and you mention it on your leaflet, to send me examples of Arduino code that successfully send sensor readings via WiFi to an email or database. For example, one of my ideas was to use your sound detector module, and each time the module detects sound (for healthcare application - snoring detection) to send the reading data to a specific email address. I believe I know how to write code to read a digital pin and use an if loop to output all negative readings. However, I don’t know how to code sending the read and desired data to a desired email address myself, so I need your help.
I also tried to read QR codes from your leaflet (attached) and enter the URL for a website, but I can’t access any page. Is the leaflet perhaps older so the listed web addresses no longer exist/are not available, or did I simply fail to access them correctly?
Također sam vam se javio vezano uz tutorial vezan uz modul za mjerenje otkucaja srca - foto ( Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics ), za što ste mi poslali tražene podatke ( PulseSensor Playground (version. 2.5.0) – World Famous Electronics llc. ) te se na tome zahvaljujem. Početnik sam u radu s CROduinom pa će možda pokoje moje pitanje djelovati smiješno , no kako pišem rad vezan uz projekte sa CRoduinom i senzorima molio bih što detaljnije i iscrpnije odgovore
Primijetio sam da kada pokrenem bilo koji example iz te skupine “PulseSensor Playground”, osim “GetingSartedProject”, Arduino IDE mi izbacuje grešku "// out of range exit status 1, Error compiling for board Generic ESP8266 Module ". Kada board promijenim u Arduino/Genuino Uno i na njemu pokrenem kod (koristeći Genuino Uno, ne CROduino Nova), sve normalno funkcionira. Razlika u kodovima je u PulseSensorPlayground libraryu koji je includean u sve kodove(exampleove) osim početnog. Mogu li se kako pokrenuti ostali exampleovi na CROduino Nova pločici ? Dali CROduino Nova ispravno radi samo ako odaberem Board “Generic ESP8266 Module” ili mogu odabrati i neki drugi Board kako bi mogao koristiti sve kodove ? Cilj mi je prikupiti očitanja senzora te pomoću WiFi modula na CROduino Nova pločici te podatke slati/pohranjivati u IOT svijetu. Također bih Vas molio, pošto ste vjerujem nešto slično radili nebrojeno puta, a i na vašem letku to spominjete, da mi pošaljete primjere Arduino koda koji uspješno šalju očitanja senzora putem WiFi-a na neki e-mail ili u bazu podataka. Npr. jedna od ideja mi je bila, koristeći Vaš modul detektora zvuka ( Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics ) svaki put kada modul detektira zvuk (za primjenu u zdravstvu je, detekcija hrkanja čovjeka) podatke o očitanju poslati na određenu e-mail adresu. Kod za očitanje digitalnog pina, kao i if petlju da izbacim sva očitanja koja su negativna, vjerujem da znam napraviti. No kod za poslati očitane i željene podatke na željenu e-mail adresu, sam ne znam iskodirati, pa stoga tražim Vašu pomoć
Također sam pokušao i očitati QR kodove s vašeg letka (u prilogu) i upisati url za web stranicu, no ne uspijevam pristupiti nikakvoj stranici. Dali je letak nešto stariji, pa navedene web adrese više ne postoje/nisu dostupne ili sam ja jednostavno nisam uspio pravilno im pristupiti ?
Originally submitted via email support on 30 January 2018. Migrated to the forum for community visibility.
