Croduino NOVA web server code fails to run with encrypted serial output
I’m unable to run your code to open your website on Croduino NOVA. I’ve checked everything I could think of that might be wrong, but I haven’t resolved the issue. I followed your setup instructions for Arduino IDE with the NOVA board, my SSID and password are correct. I’m sending you the serial monitor output and hope you can help me figure out what the problem is.
Bezuspješno pokušavam pokrenuti vaš kod za otvaranje vaše web stranice na croduino Nova. Provjerio sam sve što mi je palo na pamet da bi moglo poći po zlu, ali nisam otklonio problem (pratio sam vaše upute podešavanja arduino Ide za pločicu Nova, moj SSID i password su točni..). Šaljem vam u prilogu serial monitor te se nadam da mi možete odgonetnuti u čemu je problem.
Attachment omitted in migration: arduino.JPG
Originally submitted via email support on 6 May 2017. Migrated to the forum for community visibility.
Everything I print to the serial monitor appears encrypted and I can’t read it.
Ne trebate odgovarati na ovaj mail, skužio sam u čemu je bio problem.
Iz nekog razloga je sve što ispišem na serial monitor kriptirano i ne mogu pročitati.
The BAUD rate you set with Serial.begin() might not match the one in the Serial Monitor. Check the dropdown menu in the bottom right corner of the Serial Monitor.
moguće da Vam se BAUD rate koji ste zadali s Serial.begin() ne podudara s onim u Serial Monitoru. Provjerite padajući meni u donjem desnom uglu Serial Monitora.
