Croduino Nova2: ESP8266 board with female headers instead of soldering
I’m looking for an ESP8266 WiFi board. The two options I found don’t seem to be what I need based on the product descriptions. I’d prefer to avoid soldering. Do you have an ESP8266 WiFi board where I can connect female headers?
Pozdrav trazim ESP8266 WiFi izbaci mi dva primjerka, kada idem u opisu na rubriku detaljnije ne izgleda mi kao da je to ta “ploča” koju tražim, (ugl izbjegao bih lemljenje) dali imate ESP8266 WiFi na koje mogu spajati zenske utore? :slight_smile:
Originally submitted via email support on 18 November 2019. Migrated to the forum for community visibility.
The Croduino Nova2 is a breakout board for the ESP8266 microcontroller. The board comes without male headers pre-soldered, so you can purchase a 10-pin female header and solder it to the board yourself if you prefer that option.
hvala Vam na upitu. Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics S obzirom da s pločicom muški headeri ne dolazi zalemljeni, možete si nabaviti i 10-pinski ženski header te ga zalemiti na pločicu. Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
