I’m considering ordering a Croduino Nova2, but I see that where the pins are there are only holes. What do I need to buy so that I can have connectors like on the original Arduino, where I can simply plug and unplug cables?
Dobar dan
Hvala na odgovoru.
Imam još jedno pitanje mislim naručiti Croduino Novu 2 ali vidim da tamo gdje su pinovi su samo rupe pa me zanima što trebam kupiti da bi tamo kao na originalnom Arduinu bili utori tako da kablove mogu samo uključiti/isključiti?
Hvala
Originally submitted via email support on 28 August 2019. Migrated to the forum for community visibility.
The connectors you’re looking for are called female headers. Since the Croduino Nova2 has 10 pins/holes on each side, you need a female header set like this: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Can you solder the female headers yourself?
hvala Vam na brzom odgovoru.
Utore za kablove inače zovemo ženski headeri. S obzirom da Croduino Nova2 ima po 10 pinova/rupa za svake strane, potreban Vam je jedan ovakav set ženskih headera:
Ženske headere možete zalemiti sami?
