I purchased several Croduino NOVA32 boards, but I have the same problem with all of them. When I try to upload code to any of them I get the following stack trace:
esptool.py v2.6
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32D0WDQ5 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
MAC: 98:f4:ab:1d:9d:70
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
A fatal error occurred: Timed out waiting for packet header
The same problem occurs on both computers where I tested it.
For the board I set ESP32 Dev Module, as mentioned in the answer to someone’s question on the product page, and didn’t change anything else.
OS: Ubuntu 18.04
Arduino IDE: 1.8.12
Kupio sam nekoliko Croduino NOVA32 pločica, ali sa svima imam isti problem. Kad pokušam uploadati kod na bilo koju od njih dobivam sljedeći stack trace:
esptool.py v2.6
Connecting…
Uploading stub…
Running stub…
Stub running…
Changed.
Configuring flash size…
Isti problem događa se na oba računala na kojima sam isprobavao.
Za board sam stavio ESP32 Dev Module, kao što piše u odgovoru na nečije pitanje na stranici proizvoda, ostalo nisam mijenjao.
OS: Ubuntu 18.04.
Arduino IDE: 1.8.12
Originally submitted via email support on 2 May 2020. Migrated to the forum for community visibility.
