What should happen when the Croduino set for beginners is assembled? Should some lights light up or something? I’m considering buying this set but I’m not sure what the end result should look like.
Lp, sta bi trebalo ispast dok se slozi CRODUINO SET ZA POČETNIKE(CSP) HOBBY, kao neka svijetla bi trrbala svijetliti ili sto? Kupio bi taj set al ne vidim sta bi trebalo ispast.
Originally submitted via email support on 20 November 2018. Migrated to the forum for community visibility.
The Croduino set for beginners (CSP) is a complete system for learning programming and basic electronics principles. With this set you will be able to program the world and electronic devices around you. You will learn to program Croduino in C, connect electronic components, and learn basic facts about them. The best part about this set is that no prior experience in programming or electronics is needed to get started.
If you’re thinking of the product called “Soldering Learning Set”, that’s a completely different product. With those you can solder components and when finished you get a small device that does something with LEDs (lights up).
hvala Vam na upitu.
Croduino set za početnike(CSP) je kompletan sustav za učenje programiranja i osnovnih ekeltroničkih principa.
Uz ovaj set bit ćete u mogućnosti programirati svijet i elektroničke uređaje oko Vas, a naučit ćete programirati Croduino u C programskom jeziku, spajati elektroničke komponente i osnovne stvari u vezi njih. Što je najbolje u vezi ovoga seta - nikakvo iskustvo u programiranju ili elektronici nije potrebno za početak rada.
Maybe this is a silly question but I’m not sure… I’m starting electrical engineering at university next year, coming from a general high school background. Will this set help me with the fundamentals of electrical engineering?
Ahamm, mozda je ovo malo glupo pitanje ali nmv… sljedece god krecem na faks( elektrotehnika), a iz gimnazije sam, pa me zanima jel mi je moze to kak pomoc u osnovama elektrotehnike?
From personal experience (general high school → electrical engineering university) I can say it was quite difficult at the start. The Croduino set for beginners is an excellent resource when you need to master the fundamentals of electronics and programming. For the components and modules in our sets, there are blog posts that briefly explain their function and how to use them, accompanied by code examples. So if I’d had something like this set at the beginning, it would have been much easier for me.
Definitely a warm recommendation, and I have to praise your interest showing up this early.
hvala Ti na upitu.
Iz svog osobnog iskustva (opća gimnazija → elektrotehnički fakultet) mogu reći da je bilo poprilično teško u početku.
Croduino set za početnike je odlična stvar kada je potrebno savladati osnove. (elektrotehnike/elektronike i programiranja) Za komponente i module koji se nalaze u našim setovima postoje objave na našem blogu u kojima je ukratko pojašnjena njihova funkcija te na koji način se koriste. (praćeno s primjerom koda).
Stoga, da sam imao nešto poput takvog seta u početcima, bilo bi mi puno lakše.
Definitivno topla preporuka i moram pohvaliti tvoj interes koji pokazuješ dosta ranije.
